Melling 10296 vs. 10295
Old Jul 11, 2010 | 09:00 PM
supercharged680's Avatar
Question Melling 10296 vs. 10295
whats the difference between them which one should i go for?? anyone has it installed??
my pressure is fine untill 6000+ i have a drop.. i guess its the lifters.. but i need an oil pump thats a bit better than stock that push the oil pressure really high but i will see some increase..
regards
Old Jul 11, 2010 | 09:06 PM
scooter k's Avatar
I can't remember the difference but I have the 10296 pump in mine. I've had it in two different engines and both have different oil pressures. Great pump though.
Old Jul 11, 2010 | 09:08 PM
the 10296 comes with 2 springs ya? what are the colors? and which one did u use
Old Jul 11, 2010 | 09:30 PM
scooter k's Avatar
Red and Blue springs. One is a high pressure spring and other is stock pressure.
I used the high pressure spring that my builder recommended. They usually use the stock pressure spring on most stuff.
Old Jul 11, 2010 | 10:37 PM
10295 is high psi, 10296 is stock psi, high volume.
im runnin the 10295 in my ls1, at wot its abt 70-75 psi
Old Jul 11, 2010 | 10:48 PM
MikeGyver's Avatar
regards
Did you ever check the pressure again after switching to 5w30?
Old Jul 11, 2010 | 10:57 PM
0w40** 5w30 isnt available where i am.. im not in the country at the moment but i prefere changing the oil pump... but im sure the drop after 6000+ rpm is still there..
Old Jul 11, 2010 | 11:15 PM
MikeGyver's Avatar
... my pressure is fine untill 6000+ i have a drop.. i guess its the lifters..
Yeah, if they are letting too much oil to the top end, and the pan is emptying above 6000, it might be their fault
... but i need an oil pump thats a bit better than stock that push the oil pressure really high but i will see some increase..
regards
A stock pump should be OK, maybe your relief valve spring is weak.
Old Jul 11, 2010 | 11:19 PM
i think putting the 10w60 before switching to the 0w40 may weak'nd the relief valve spring..does the reliefe valve spring come with the oil pump, i may be going for 10296 using the lower pressure spring.. , also LS7 lifters may fix the drop.. how many liters of oil is recommended for my engine? 6.2..
Old Jul 11, 2010 | 11:23 PM
MikeGyver's Avatar
Get the standard-volume pump. It comes with two springs, one installed. Put in the high pressure spring. The high volume pump is not needed.
