Main Cap and Rod Bolts
Old Jan 17, 2011 | 10:33 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by Robert91RS
If I remember correctly, use of ARP rod bolts requires machining of the rod to bring it back into spec. The higher clamping force distorts the rod.
I had read this a long time ago also, but if you ask any of the guys here at PT.net who have done ARP rod bolts, all they have done is remove the sleeves from the factory bolts and torque the ARP's as necessary
Old Jan 22, 2011 | 04:29 AM
chrisfrost's Avatar
Hello , I don't know if You still need part#'s but if so , the mains are #12560272 (10) , # 12560273 (10) . Those are the large bolts and the studs . I don't have the side bolt #'s or the rod bolt #'s handy . If You need those also You can reply on this thread and I will dig them up for You . Good luck
Old Jan 24, 2011 | 04:54 PM
Steve-O-08's Avatar
Sweet, thanks.
5.3Okasai
Mar 9, 2022 01:07 PM
greedygenius
Sep 3, 2015 06:51 AM
Jake75
Aug 5, 2015 01:26 PM
steves86ta
Jul 28, 2015 10:21 AM
Ammadien
Jul 22, 2015 08:50 PM
