The LS9 in photographic detail
Old Feb 9, 2008 | 08:53 AM
DrX's Avatar
DrX
Default The LS9 in photographic detail
Here's an exploded view of the LS9/R2300 engine:
Individual parts photos here: http://jalopnik.com/337672/detroit-a...ful-ls9-engine
Notice that the crank pulley is now keyed. Wonder if the 11 rib setup can be made to work on a truck?
Old Feb 9, 2008 | 10:33 AM
Moddoo's Avatar
Kick ***
Let the swap threads begin!
Old Feb 9, 2008 | 10:35 AM
Bill Reid's Avatar
If you wanted to utilize the entire accessory drive I don't see why not... with a custom aftermarket harmonic balancer but might have to come up with a custom front blower drive for correct alignment. With the factory dry sump, and its dual rotar setup, it requires a special offset balancer. So, you couldn't just use the balancer shown and expect everything to line up with a regular ole oil pump. F-Body guys went through the same thing trying to adapt the LS7 with their accessory drive. ATI wound up making a special offset balancer for them.
What will be interesting is if the blown truck motor will actually make it to market. Pics shown below. I could see THAT accessory drive being a bit more adaptable...
Old Feb 9, 2008 | 10:53 AM
DrX's Avatar
DrX
The article does state that GM has a few more blower motors in the works.
Texas5.3_1251
Mar 5, 2016 08:10 PM
mikeyjm1
17
Oct 29, 2015 11:04 PM
jscherbs
Sep 30, 2015 07:54 AM
JoshH
Sep 28, 2015 11:19 AM
97_ek
Sep 23, 2015 09:16 PM
