LS9 cam swap into L9H
Old Nov 13, 2014 | 12:12 PM
JD8310R's Avatar
Default LS9 cam swap into L9H
Am going to be doing the LS9 cam swap into my L9H. With that being said the only question i need reassurance on first is, is swapping valve springs necessary? From what i understand the Part # for the l92 and LSA (cts-v) springs are the same and (LS2/LS3/LS9 springs are same). I may be beating dead horse but would like to get a second opinion so if needed it can all be done at same time while the truck is down.
Old Nov 15, 2014 | 12:48 PM
69Camaro427's Avatar
What springs are in the LH9? having a hard time finding them. Regardless you will need minimum LS9 0.570 max lift for the ls9 cam, probably wouldn't hurt to get some 0.600 single springs.
Old Nov 17, 2014 | 08:54 AM
Vortec350ss's Avatar
I didnt think the truck came with the springs you need... but I could be wrong.
That said... the LS9 cam isnt a great fit for your truck. That cam tends to make the bottom end power feel soggy and the truck youre putting it in will amplify that. DO you have a converter? What RPM do you hit it with the bottle?
Old Nov 17, 2014 | 02:11 PM
JD8310R's Avatar
I just know the LSA and L9H/L92 springs are the same. just wasn't sure if factory springs would work. If i have to leak it down and put longer singles or duals in it i might as well get a bigger lift cam with similar duration and lsa.
Old Nov 17, 2014 | 02:23 PM
The LSA has a little baby cam like those other motors. You will need to do a spring swap.
Old Nov 28, 2014 | 05:13 PM
Sorry to bring up an old thread, but what does one do to not get a ses light with the removal of the cam phaser when swapping to the 3-bolt ls9 non-vvt cam?
Old Nov 29, 2014 | 10:41 AM
turboal1's Avatar
Default Ses
disable the setting in the PCM
Old Jan 7, 2015 | 04:50 PM
gunter96ws6's Avatar
Doing this mod soon, had the parts for months just been waiting on deer season to end so the truck can be down. We need a big thread for this mod, I've seen several 6.2 guys do it. Good luck op.
Old Jan 29, 2015 | 04:27 PM
KALVERT's Avatar
anybody done it yet? how are yall's trucks running?
5.3Okasai
Mar 9, 2022 01:07 PM
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Aboss
Jul 9, 2015 10:28 AM
