LS9 cam on a 99 silverado what should i know?
Old Nov 19, 2019 | 05:43 PM
dantheman1540's Avatar
Google "summit racing 212/218 low lift cam shaft" pretty sure the exact one will pop up
shakenfake's Avatar
Shlumpt
5 Year Member
Originally Posted by dantheman1540
NA means naturally aspirated. So no turbo, no super charger and no nitrous oxide. Just a regular old V8 sucking air and burning gas!
Thank you!! I feel like a dumbass for that one
Old Nov 19, 2019 | 05:45 PM
shakenfake's Avatar
Shlumpt
5 Year Member
https://www.summitracing.com/parts/cca-k20-212-2
Is this it? Cheaper than the brian tooley one by about $100
Old Nov 19, 2019 | 05:50 PM
No! That part number is ironically similar to the cam specs but that looks like it's for some big Mopar motor.
Here is the cam I'm referring to https://www.summitracing.com/parts/btc-tck-b-2/
Old Nov 19, 2019 | 05:53 PM
It's ok to feel like an idiot these forums are slam full of amazing information. I can guarantee that 99% of the questions you have are already answered here. It just takes time reading and figuring out what to search to find the answer.
Some members get annoyed with newbie questions but they all probably started asking the same stuff. Just keep learning everything you can.
Old Nov 19, 2019 | 06:03 PM
shakenfake's Avatar
Shlumpt
5 Year Member
Well off to asking about and learning about headers, thank you
Old Nov 21, 2019 | 07:30 AM
Drspencer's Avatar
5 Year Member
Long tubes or no tubes. If you're not spending the money on long tubes, maybe get the factory manifolds ceramic coated....
Old Nov 21, 2019 | 08:29 AM
wretched73's Avatar
Why in the world would he get the factory manifolds coated?
I'd agree, go long tubes or stay stock, no in between but I can't see the point in doing anything to the factory manifolds
Old Nov 21, 2019 | 08:33 AM
shakenfake's Avatar
Shlumpt
5 Year Member
Yes I was planning on getting long tubes with the y pipe found some for $280 or so seem decent enough
Old Nov 21, 2019 | 04:34 PM
chevykev's Avatar
I have a ls6 cam in my 5.3 truck and it’s a nice cam for the buck(stock cam) I got a 212/218 I’m throwing in so the ls6 cam will be for sale once it’s pulled. I just beat a dodge Cummins the other night from a dig at a light. Once the converter flashes the cam rips. I can only imagine the 212/218 with supporting mods but that will get a turbo at the same time so it will be even better. But ls9 cam isn’t the best cam unless you rev it or wot everything. Even then it’s a dog. I had one and traded it for 4l80 core. Try ls6 used in a smaller cube motor (5.7 vs 6.2) it will pair nice with a 2800k converter and bolt on mods. if you can find some 799 or 243 heads of run them . Just a thought. Cheap mods you’ll net 50+ Then 100-150 shot of juice and you have a nice street truck
