LS7 lifters milled .30 862 for 5.3L, what pushrod length???
Old Jan 18, 2013 | 08:46 AM
Camin00's Avatar
Default LS7 lifters milled .30 862 for 5.3L, what pushrod length???
I currently have 7.4s
I am ordering a pushrod length checker with my new pushrods
The truck is a daily driver so it can't sit in the shop waiting on pushrods to come in the mail.
What length worked for you with this set up??? I was thinking 7.35 Would work till I know for sure with the length checker to order the exact ones.
Old Jan 18, 2013 | 09:10 AM
03regcab sierra's Avatar
7.375 should work
Old Jan 18, 2013 | 09:17 AM
Beau@SDPC's Avatar
Trucks Sponsor
There is no clear cut answer in a situation like this. Length needs to be checked first. Order the checker, measure, then order pushrods. Just my suggestion.
Old Jan 18, 2013 | 11:28 AM
Ferocity02's Avatar
I have a similar setup; 5.3L LM7, Ls7 lifters, 799 heads milled 0.022, LS9 head gasket (stock thickness) and I'm running 7.325" pushrods to get me around 0.075" preload, measured with an adjustable pushrod and dial indicator. But as mentioned, you must measure to know for sure.
Old Jan 18, 2013 | 12:26 PM
dmelvin's Avatar
Also a similar setup. LM7, 243's milled .030, LS7 lifters, .040 thickness gasket ---- 7.350 pushrods.
Old Jan 18, 2013 | 01:19 PM
Beau@SDPC's Avatar
Trucks Sponsor
OP, see what I'm saying....3 different lengths with similar setups. Best to measure first, and not regret it later.
Old Jan 18, 2013 | 01:20 PM
Ferocity02's Avatar
Whats your preload? It's a little worrying that no one else is using pushrods as short as mine
Old Jan 18, 2013 | 02:52 PM
way2much_01's Avatar
Actually I'm using the same length as you but I did check mine nore than once
But like everyone said its best to be safe than sorry...
Old Jan 18, 2013 | 05:10 PM
Ferocity02's Avatar
Ah good. Not too many people using pushrods this short. I measured every valve with a dial indicator and the average was around 0.075". Not sure exactly what the high and low were, but the spread was probably 0.015-0.020".
Old Jan 18, 2013 | 06:38 PM
Hivelocit's Avatar
Definitely order the checker, I assumed mine was 7.4. After installing they were too tight, and after getting the checker I realized I was .05 off. Checker was around $25 and is cheap insurance!
BigE
Feb 21, 2018 11:44 AM
Texas5.3_1251
Mar 5, 2016 08:10 PM
chevstang421
Sep 10, 2015 09:16 AM
chvy=power
Sep 8, 2015 11:06 AM
PDPERFORMANCE
Sep 8, 2015 11:01 AM
