ls7 cam
hey, was wondering if the 2006 and up ls7 stock camshaft and springs work in the gen 3 motors. And what are the specs on these cams. Looking at getting one, just hope it works, and is good for a turbo setup!!
cory
cory
i'm pretty sure theres a bunch of other stuff you gotta do to make it work, i thought i remember reading that you'd need a diff style t-chain, maybe water pump? i'm not too sure, but i'm pretty sure its not plug and play.
Well the cam is a pretty good grind....
And yes you can convert it to work, (if you have an older truck) but......
Remember that the Z06 has larger ratio rockers... something that your trucks won't have stock. So even though they are pretty cheap.... you might as well go with a custom grind for your application, or and off the shelf cam.
BennyB
Aug 1, 2015 08:48 AM
