ls7 cam
Old Feb 24, 2008 | 06:34 PM
coryhussey's Avatar
Default ls7 cam
hey, was wondering if the 2006 and up ls7 stock camshaft and springs work in the gen 3 motors. And what are the specs on these cams. Looking at getting one, just hope it works, and is good for a turbo setup!!
cory
Old Feb 24, 2008 | 06:51 PM
wastedrubber's Avatar
i'm pretty sure theres a bunch of other stuff you gotta do to make it work, i thought i remember reading that you'd need a diff style t-chain, maybe water pump? i'm not too sure, but i'm pretty sure its not plug and play.
Old Feb 24, 2008 | 09:32 PM
ZO6Ted's Avatar
Thats what I recall also. There is a thread on it.
Old Mar 5, 2008 | 08:54 PM
E.A.'s Avatar
Well the cam is a pretty good grind....
And yes you can convert it to work, (if you have an older truck) but......
Remember that the Z06 has larger ratio rockers... something that your trucks won't have stock. So even though they are pretty cheap.... you might as well go with a custom grind for your application, or and off the shelf cam.
OHsixLS3
Dec 27, 2016 09:30 AM
DrX
Aug 19, 2015 04:45 PM
JordanH
Aug 8, 2015 07:59 PM
BennyB
Aug 1, 2015 08:48 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
