LS6 intake swap what to do w/EVAP ?
Old Aug 25, 2008 | 06:40 PM
Raffman's Avatar
Default LS6 intake swap what to do w/EVAP ?
Did a search, I swear. My 02 5.3 has a evap solenoid on the intake manifold. I'm swapping in the 6.0 with a LS6 intake and doesn't seem to have a provision for it ......what to do.
Old Aug 25, 2008 | 06:54 PM
nonnieselman's Avatar
Here is what i did with mine cause it was in the way of the Nitrous/Fuel lines..
Old Aug 25, 2008 | 07:56 PM
Raffman's Avatar
Good idea, remote mount. Wasn't sure if it was something that could be eliminated or not. Thanks
Old Aug 25, 2008 | 08:24 PM
amadeospike's Avatar
It can be deleted with HP tuners. Or at least the code can be deleted.
Old Aug 25, 2008 | 08:28 PM
dirt track racer 81's Avatar
mine had melted from a fire after a fuel injector popped out..i just cut it back and turned it all off in the pcm
Old Aug 25, 2008 | 08:30 PM
bluecajun5.3's Avatar
11 Second Truck Club
i stuck a piece of hose on the bottom side and hooked it up to the intake.
here's an old pic of mine...
Old Aug 25, 2008 | 10:05 PM
well i didnt want gas fumes floating around under the hood and that was the most simplest thing i could think of, and it works the same by pulling vacuum.
Old Aug 26, 2008 | 07:30 AM
Raffman's Avatar
I thought about just connecting the line to a vacumn port but the idea of the solonoid opening under high vac sounds better. There must have been a reason for GM to do it that way.
Old Aug 26, 2008 | 01:03 PM
thunder550's Avatar
High on diesel fumes
I moved mine too and just ran some hoses to it.
5.3Okasai
Mar 9, 2022 01:07 PM
byrne_06
Apr 29, 2017 02:19 PM
The_W
Oct 28, 2015 09:00 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Aboss
Jul 9, 2015 10:28 AM
