LS6 cam thoughts
Old May 9, 2009 | 01:43 AM
grey matter 04's Avatar
13 Second Truck Club
Default LS6 cam thoughts
Who is running the 02 and up ls6 cam in a N/A 5.3?
What kinda power and track times they are producing?
Wanting to put this in my daily driver,reason being i dont want a big or choppy cam,want something mild mannored with decent gains.
Went to my local performance shop and they said that cam is junk your wasting your time!
My 04 ecsb silvy 5.3,want a low 14 sec truck!
As of now it runs 15.1 at 93 on 20s with a 2.4 60ft
Mods are tune,magnaflow muffler,k&n cold air intake
Old May 9, 2009 | 01:54 AM
charcold-bowtie's Avatar
a big stall converter will produce better than that cam.
the only reason it is prefered is cause its a great boost cam. AND the price.
It didnt make ANY power in my 4.8 till about 3500 rpm. So with no stall, it was complete crap.
Old May 15, 2009 | 11:03 PM
what pushrods did you go with?
Old May 15, 2009 | 11:11 PM
7.400 with no regrets
Old May 15, 2009 | 11:24 PM
and springs, did you use the yellow LS6 springs
Old May 16, 2009 | 09:43 AM
bluecajun5.3's Avatar
11 Second Truck Club
they are right!
if you really want an ls6 cam go with the 01 b/c it has less duration.
also you can look into comps 206/212 or their 212/218.
Old May 16, 2009 | 09:58 AM
Stoichiometric's Avatar
I don't think the factory cams have any advance, so if that is true the 01 ls6 cam has a 116 ICL and should make power a little sooner than the 02+.
Old May 16, 2009 | 10:07 AM
budhayes3's Avatar
PT's Slowest Truck
Hey, there's the answer you were looking for I thought the LS6 cam needed 7.425's due to the smaller base circle
Old May 16, 2009 | 04:42 PM
the stock pushrods work cause i just measured it this morning. wow. this is the Z06 factory cam, 550/550 117 lsa, straight from GM hot cam. thanks for the help.
Old May 16, 2009 | 07:12 PM
Op honestly my comp 212/218 has a stockish idle, plus it gave me a decent gain all around.
