LS6 cam in a stock 5.3 is it worth it?
Old Jan 23, 2013 | 09:17 AM
Terry Theriot's Avatar
Default LS6 cam in a stock 5.3 is it worth it?
I have a 2001 5.3 that I'm putting into a 1953 chevy Belair with a 200R4 transmission and 3.90 gears. I have a stock set of 852 heads and I plan to install a dual plane intake with a 650 to 750 carb. This is mostly for crusing but I wanted a liitle more than the stock truck cam. Will the LS6 cam work and would the pistons need to be flycut. I plan on putting LS6 springs and pushrods.
Old Jan 23, 2013 | 09:37 AM
53bowtie's Avatar
I think it would be worth it if you have the cam or can get it at a good price. Grey Matter put one in his truck I believe and saw a good improvement in his 1/4 time maybe he will chime in. I dont know if it would perform differently with a carb setup though.
No you will not have to fly cut pistons the LSA on the LS6 cams is somewhere around 117 and the lift is only around .550 I believe.
Old Jan 23, 2013 | 02:49 PM
grey matter 04's Avatar
13 Second Truck Club
Yep it has proved itself to me.
Go for it good budget cam with sleeper idle
I responded to his pm
Old Jan 23, 2013 | 03:17 PM
Beau@SDPC's Avatar
Trucks Sponsor
I am running the same cam in my CC and love it. Good power for such a small cam. Very tame idle. Makes for a great daily driver.
Old Jan 24, 2013 | 06:47 AM
JDC's Avatar
JDC
Worked nice in mine but I also had the 243 heads. You'll want a stall in it also.
Choda
Jan 22, 2026 02:03 PM
5.3Okasai
Mar 9, 2022 01:07 PM
steves86ta
Jul 28, 2015 10:21 AM
bk_cauley
Jul 19, 2015 09:56 PM
Atomic
Jul 11, 2015 03:51 PM
