LS2 head vs LQ4 head
Old Feb 25, 2009 | 05:05 PM
DAH32's Avatar
Default LS2 head vs LQ4 head
What is difference in these two heads?
It appears the LQ4 head has bigger cc's and smaller runners?
Does the LS2 head have smalller cc's and larger runners?
ALSO
Would a stock LS2 cam be OK with stock LQ4 valve springs?
Thanks
Old Feb 25, 2009 | 05:25 PM
regency's Avatar
basically the same head in theory! LQ4 head "317" and LS2 head "243"
317 - same runners and flow as the 243. 72cc combustion chamber
243 - same runners and flow as the 317. 64cc combustion chamber
WAY too much to be milled off the 317 to get the 64cc of the 243.
You be the judge, but i would think you could use it
LS2 cam specs: 200/203 - .500/.500
LQ4/9 cam specs: 196/207 - .467/.479
Old Feb 25, 2009 | 05:37 PM
DAH32's Avatar
Do you know those advertised duration numbers for those cams? I seem to be having a hard time finding those numbers.
72cc's down to 68 cc's is not that much in my opinion.
Old Feb 25, 2009 | 06:06 PM
regency's Avatar
68cc???
GM doesnt have an advertised # for the cams! thats only for aftermarket stuff
Old Feb 25, 2009 | 08:01 PM
DAH32's Avatar
Yeah, I jst through that number out there. I'm wondering how to get the max amount of power and bleed off enough pressure. It is hard to figure out DCR without adv. duration.
greedygenius
Sep 3, 2015 06:51 AM
Verz
Aug 21, 2015 06:40 PM
Ammadien
Jul 22, 2015 08:50 PM
jmarkway
Jul 18, 2015 09:23 PM
caviness
Jul 5, 2015 10:49 PM
