LS1 heads on a 5.3
Old Jan 30, 2010 | 04:19 PM
LOUDMAN's Avatar
Default LS1 heads on a 5.3
Putting together a 5.3 and I have a set of LS1 heads and a set of 5.3 heads. Both stock. Just out of interest was wandering if anyone new which head would be a better choice on a slightly modified setup? Not looking to modify the heads.
Old Jan 30, 2010 | 04:22 PM
RibeiroBJJ's Avatar
Praise The Lowered
You will lose power with the ls1 heads due to the larger Chambers...get a mild port and 3 angle valve job on your stock heads...........
Old Jan 30, 2010 | 06:06 PM
budhayes3's Avatar
PT's Slowest Truck
I'd talk to Richard at WCCH and see what they have to offer...they used to have a StageI 5.3 head that tdrumm was running on his truck. IIRC, they were worth 20 or 30 HP on the dyno.
Old Jan 30, 2010 | 08:14 PM
regcabls6's Avatar
richard ported my 706's (5.3) and they flow just under 300cfm. infact im goin to use them on the 402 im building.
Old Jan 30, 2010 | 10:10 PM
ATTITUDE ADJUSTER's Avatar
trans ams have 241s i think the 241s have biger valves than the 706s.if u mill them wont that be enough to compensate for the larger combustion chamber???
Old Jan 31, 2010 | 10:44 AM
acethedragon's Avatar
ls1 and 5.3 heads are the same. only difference is the ls1 chamber is a little bigger by 3 to 4cc. valves and ports are same. Attitude, your thinking bout the 243s. they have bigger ports and intake valve. Loudman, just look into a little port work on the 5.3 heads and it will rock.
Old Jan 31, 2010 | 10:47 AM
RibeiroBJJ's Avatar
Praise The Lowered
Intake valves are larger as well..
Old Jan 31, 2010 | 02:54 PM
LOUDMAN's Avatar
Thanks. seems like the 5.3 heads sound like the better option. Now just throwing this out there as food for thought, since this is just a temporary backup, if i have the block bored to 3.90 would it be better to port the 5.3 heads or just use the LS1's.
sorry bout the hypotheticals just dont want to spend a lot of money on this set up but dont want to put together a complete turd.
comparing 852's to 241's if it make a difference
Old Jan 31, 2010 | 07:45 PM
01midmetws6's Avatar
Incorrect kind Sir,
243's and 241/853's share 2.00/1.55 valves. 5.3 heads have 1.89/1.55" valves and a 61.1cc chamber. 241's have a better casting that supports higher flow than the 853's. 243's are the best factory LS1 style head to date with 64.5cc chamber and a more efficient chamber and port design that is nearly identical to the 317 (317 uses a 71cc chamber).
If you are thinking about doing a set of budget heads find some 243' for $450 on tech and get them milled .030" to get a chamber that is the same size as a stock 5.3 but promote much better flow. Or simply get your stockers ported by a "reputable" company. If you already have some 241's you can cut .035-.040 off of them to retain stock compression and add a little extra power.
Old Jan 31, 2010 | 08:53 PM
LOUDMAN's Avatar
would shaving the heads cause clearance issues with a high lift cam?
