Lq9 tsp228r
Old Mar 28, 2011 | 11:56 AM
BadAssChevy327's Avatar
Default Lq9 tsp228r
Well I'm fixing to order a tsp 228r. When I do the swap I was gonna pull the 317 off and shave them 30 and do some hand porting.
You guys recommend some keys areas on a 317 to touch up or a better cam? It will have a 3600 to 3800 shortly.
Old Mar 28, 2011 | 12:06 PM
LS1TRUCKGUY's Avatar
You could get away with a little less converter with that cam. Or you could go with a bigger cam with that converter... I think it will be a tourquey **** with that 228/228
Old Mar 28, 2011 | 12:11 PM
Well a 3600 most likely. Also it's getting head studs and I plan to hit it with a 175 to 200.
I was thinking a v3 and John at tsp recommends it but I'm worried about piston to valve clearance after shaving the heads
Old Mar 28, 2011 | 12:37 PM
budhayes3's Avatar
PT's Slowest Truck
What are the specs on the v3?
Old Mar 28, 2011 | 01:20 PM
MPFD's Avatar
11 Second Truck Club
Your 3600 will flash like a 4000 on a sprayed hole shot...
Old Mar 28, 2011 | 06:46 PM
Mpfd, what does ur converter flash to on n20? I have a pt3800 but I haven't sprayed it yet with this converter
Old Mar 28, 2011 | 06:49 PM
what are the specs on the v3?
231/234 643/598
Old Mar 28, 2011 | 08:35 PM
MPFD's Avatar
4000 or better depending on the shot size...
Old Mar 29, 2011 | 09:50 AM
06Sierra2's Avatar
thats a lot of lift on the intake side of the v3 damn! what about a custom grind?
Old Mar 29, 2011 | 06:08 PM
1slowz71's Avatar
Did you tell them you were planning to mill your heads ?
