Lq9 Compression
Stock is 10.1:1 with an LQ9. I'm not sure how many cc's 0.030 worth of milling will remove (have a cold, brain won't work
) but I think it takes you down to the 65cc range with 317s.
If that's right, then after the mill you'll be around 11ish:1 with LQ9 flattops and MLS gaskets.
) but I think it takes you down to the 65cc range with 317s.If that's right, then after the mill you'll be around 11ish:1 with LQ9 flattops and MLS gaskets.
