LQ9 Build Advice
Old May 15, 2016 | 04:10 PM
Chevy6.Zero's Avatar
Thanks for the replies everyone! Did I look like I was missing anything in my parts list?
Old May 15, 2016 | 04:34 PM
Wolftrk99's Avatar
List looks good, heard too many horror stories about fast intake, aside from cost, with fuel rails sensors etc not fitting properly....
Old Sep 20, 2016 | 02:38 PM
Default Update
Ok so I talked to Texas Speed and told them about my goals and they recommended the following. Please let me know what y'all think or if y'all have any other input.
Cam: Texas Speed Torquer V4 231/234 .629/.615 111 lsa
Heads: PRC As-Cast 225cc LS1/LS2 Cathedral Heads with 62cc Chambers
Valve Springs:- PRC .650" Lift Dual Valvesprings with Titanium Retainers
Lifters: LS7 Style Lifters
Timing Chain: LS2 Timing Chain
Oil Pump: TSP Ported Oil Pump
Headers: TSP 1 7/8" Stainless Long Tube Headers
Still need to figure out:
-Injectors
-Fuel Pump
-Intake
-Stall (I have a stall right now but its only a 2100 and I don't think that will be enough)
So with this heads and cam setup is 400 rwhp achievable? Thanks for your input!
Old Sep 20, 2016 | 03:08 PM
FFDP's Avatar
Stock heads will get to you to 400 horsepower, so you could save a big chunk on money there.
Marine 8.1 injectors are like 42lbs I think, those should be plenty of injector. A walbro 255 fuel pump will be good.
NNBS intake manifold like we have talked about before in this thread.
Old Sep 20, 2016 | 11:28 PM
Ok thanks for your response! If the stock heads will get me over the 400 rwhp goal thats great but if I can make more, I'm willing to. Also something I forgot to say the truck is a 2500 on 33s so drivetrain loss will be greater.
Old Sep 23, 2016 | 11:33 AM
GRRR65GTO's Avatar
I wouldnt get your hopes up too much on the 400 rwhp. Im the same boat as you, 33s on a 2500 4wd. When I had my old turbo at 7 psi it only put down 380 rwhp. At the crank yeah 400 no problem. Like right now I put down 460 with a bigger turbo and 11 psi but guys with my same setup in a 2wd make 500-550 all the time. Dont get hung up on numbers thats what I had to learn
Jlipton72
Aug 2, 2016 08:11 AM
LS1Silverado98
Mar 27, 2016 10:00 PM
4.8Silverado'06
29
Mar 9, 2016 11:24 AM
brent1976
Mar 6, 2016 07:08 AM
About20ninj45
20
Mar 1, 2016 08:58 PM
