Lq4 rebuild. L92 heads?
Old Jan 17, 2010 | 12:53 PM
trenz68's Avatar
Default Lq4 rebuild. L92 heads?
I have a 04 RCSB with a Lq4. Performance upgrades will include under drive pulley, Pacesetter LTs, Full exhaust, 3000 yank, 4.11s. "Tootall" installed a 226/230 584 591 -112+4 cam and mentioned one of my heads might have a bent valve. Should i get my 317s worked or go with the L92 heads and intake?
Old Jan 17, 2010 | 01:04 PM
acethedragon's Avatar
if you have the funds, get the l92s, but your gonna need heads, intake, and rocker arms. if not in the budget, just have your 317s cleaned up
Old Jan 17, 2010 | 01:11 PM
trenz68's Avatar
i want to make some n/a power
Old Jan 17, 2010 | 01:18 PM
dont we all til we can afford a blower. lol. i prefer turbos. one day i will put mine on
Old Jan 17, 2010 | 01:21 PM
zippy's Avatar
Have you thought about 243's or even a stage 2.5 5.3L head? The L92's are a great upgrade, but both the 317 and L92 head are big chamber on a low compression engine. For about the same cost or a little less than the L92 swap you can do a bad *** 243 or re-worked 862 casting and get the compression to well over 10:1 netting similar hp as the L92's with a big gain in torque.
Old Jan 17, 2010 | 01:32 PM
could just get ls3 heads. they are small chamber l92s
Old Jan 17, 2010 | 01:42 PM
Tootall's Avatar
check out Skeet's setup . . .
RCSB:FULLY BOLTED LQ9 6.0,EWP, L92 heads stage 2,FAST LSXr intake,FAST #50lb Injectors,232/238 .6xx lift cam,E-fans, 160 Stat,UD pulley, FAST 102 MM TB,Tuned By Flaco,4000 Triple Disc PI stall,4l60E tranny Performabuilt, 4:10 gears, Auburn Pro Series LSD.Kooks Headers(Lt's) Full 3" Dual Exhuast to 2 Borla XR-1 Mufflers & 4 Link with QA1 adjustables sitting on Bogarts!
Old Jan 17, 2010 | 01:46 PM
trenz68's Avatar
[QUOTE=Tootall;4374884]check out Skeet's setup . . .
yah ive read his threads and sent him a pm. thanks for all your help matt
Old Jan 17, 2010 | 01:47 PM
trenz68's Avatar
Funny cause i just took off the blower,cam,springs it had
wonder if the 2.5 5.3s will be better over some 243s worked
Old Jan 17, 2010 | 01:57 PM
zippy's Avatar
They are both 70cc. The compression gain in the LS3 over the L92 is in the piston.
