lq4 questions
Old Jun 25, 2009 | 12:53 PM
bad cutt's Avatar
Default lq4 questions
I am building a 6 liter for my sierra. my 5.3 broke a piston so i might as well step up to 6.0 my truck is a 2003. i believe it has a 24 tooth reluctor so what years lq4 have the same. also i have 6.125 eagle h beam rods that i plan on using. what is the stock rod length with the 6.0 and i would also like to find the stock deck height and stroke. thanks.
Old Jun 25, 2009 | 01:25 PM
nonnieselman's Avatar
what year is your truck?
99-07s have the 24x tooth reluctor wheel..
unless yours is a 08 new body style it has the 58x wheel.
Old Jun 25, 2009 | 01:57 PM
RandomHero's Avatar
Just don't buy a 99-00 engine. Inferior in several ways.
Old Jun 25, 2009 | 02:07 PM
bad cutt's Avatar
MY TRUCK IS AN 03
all 99 through 07's have the 24x thats good to know. did they use the 58x on the gto's? for some reason i was told it needed to be a 01-03 to have the 24x.what about the rod length will i be able to find pistons to work with my 6.125 rods?
Old Jun 26, 2009 | 08:55 AM
bad cutt's Avatar
what size chambers are the stock 5.3 heads?
Old Jun 26, 2009 | 01:35 PM
ramdaspadhye's Avatar
Stock rod length is 6.098 on ALL LS motors except the 4.8, which has a 6.276 rod.
Stock LQ4's have a 9.4 compression. You can take the 317 heads and have them milled .040 to give approx 64cc chambers, which will bump the compression to around 10:1 with a .041 gasket. You must be careful though when milling and running a cam with large duration/high lift when you run into PTV clearance. It's always nice since you're gonna have the head off to clay it to see what your PTV clearance looks like with whatever cam you decide to go with.
In all honesty, the GM hotcam runs well in the 6.0's. Peaks torque around 5100rpm's and peak HP around 6100, which is pretty decent for a truck and doesn't have rediculously high lift. You can expect to have around 450-475 crank hp out of a LQ4 (stock) with the hotcam when tuned properly
Old Jun 26, 2009 | 01:57 PM
AndysC3's Avatar
I wish I could see those numbers out of my LQ4. Ive added a intake, exhaust, and about to add a TR224 114LSA cam, and a tune, and Ill be around 425HP
Old Jun 26, 2009 | 02:14 PM
When I say stock, I mean stock internals and whatnot. You'll need a nice exhaust to maximize your gains, ie longtubes and duals with x/h pipe
Old Jun 26, 2009 | 03:02 PM
AndysC3's Avatar
I have duel exhaust with two single in/out flowmaster 50s, with 3" pipes. Im about to add some pacesetter long tubes and some high flow cats. and even then Ill be luck to reach 450HP
Old Jun 26, 2009 | 07:32 PM
okay, maybe 475 is stretching it a bit with the stock intake :/
