Lq4 cam swap
Old Nov 5, 2010 | 10:24 PM
KozzyJr's Avatar
Default Lq4 cam swap
so i narrowed it down to three different cam by texas speed & performance:
Texas Speed 224/224 XE Camshaft
TSP Custom 224/224, .566"/.566"
Texas Speed 224R Camshaft
TSP XS Series Camshaft: 224/224, .581"/.581"
Texas Speed 228R Camshaft
TSP XS Series Camshaft: 228/228, .588"/.588"
i have a goal for at least 380+rwhp and a budget of $1500, have any of you guys run these cams in there 6.0s thoughts/opinions and how are they for a DD.
Old Nov 5, 2010 | 10:25 PM
Daryn's Avatar
Formerly darynC-10/23/10
i would recommend futrals 224/228 on a 112
Old Nov 5, 2010 | 10:32 PM
KozzyJr's Avatar
i wanted to stick with tsp because of there cam packages for under $600 with cam, springs and push rods cant go wrong
Old Nov 6, 2010 | 03:03 AM
Daryn's Avatar
well if you want to keep your motor do not get the comp 918 springs. get pac's or duals
Old Nov 6, 2010 | 04:05 AM
Parke10's Avatar
I understand where yer coming from when you say that,but things can happen either way, i personally know someone whos broke a pac that was well under what it was rated for, and the shop i go to uses 918s and has never had a customer break one.
Old Nov 6, 2010 | 04:15 AM
Daryn's Avatar
search around here you will find alot of people who break 918's me and a buddy of mine had some break in our vehicles. go with a double spring with a lighter spring rate .
Old Nov 6, 2010 | 04:23 AM
Parke10's Avatar
Im not denying they break, ive seen plenty on here, im just saying that u cant toss 918s out the window because of that, yes they do break more often it seems, just saying that anything can happen with any brand you run
Old Nov 6, 2010 | 05:28 AM
Daryn's Avatar
thats why you run double springs. if one breaks. you still have one to keep from dropping a valve
Old Nov 6, 2010 | 07:00 AM
ByuTrukr's Avatar
formerly ByuTrukFreak
Look at the split pattern cams they usually work better, talk to someone who works in a cam place, that will take into account all the mods u have and let them give u a recommendation. I was running a 226/226 .585/.585 112 LSA cam in a 5.3 and it handled it well.
Old Nov 6, 2010 | 07:40 AM
Beatdown Z's Avatar
Laid Back
I would go with the single pattern 228. I have Thunder Racing's single pattern 224 in my truck and I feel it could use a little more topend power.
