LQ4 BEST complete rotating assemblies?
Old Aug 25, 2010 | 11:14 AM
budhayes3's Avatar
PT's Slowest Truck
The only thing that I can think of is maybe no coolant flow around those cylinders causing the cylinders to heat up and seize the rings to the pistons. I'd think that if it was an oiling issue you'd lose a bearing before you'd weld the rings. The machine shop should have hot tanked the block which should have cleared the coolant passages. Does anybody know if it's possible to put a head gasket on incorrectly and block coolant flow? I know that was possible to do on certain V6 Toyotas and it would cause an overheating problem that was a bear to diagnose...
Old Aug 25, 2010 | 10:06 PM
Remember_54's Avatar
thank a lot, will check it, BTW which pistons tops is best for my engine which
use magnacharger on it-29cc or -16cc, or any other
one, please guys advice
Old Aug 26, 2010 | 12:56 PM
guys waiting for answer : what is the best for my engine pistons top, to use with
one
thanks in advance, i think 9:1 compression is good for charger
Old Aug 26, 2010 | 03:03 PM
z71gmc06's Avatar
I'm not an expert in this area but a quick search showed many threads like this one.
Try putting in search for "compression FI charger" or other such terms.
https://www.performancetrucks.net/fo...for+fi+charger
Raffman
Jul 23, 2018 02:26 PM
Knightcrawler
Jul 20, 2016 03:29 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
zraffz
Sep 8, 2015 07:40 PM
USMCvet0311
Sep 4, 2015 09:43 PM
