LQ4 with 706 heads = more power AND mpg????
Old 11-20-2010, 04:47 PM
  #21
GMCtrk's Avatar
Originally Posted by fastnblu
18's made that big of a diff. for you? That kinda ironic, 18's or maybe 20's are what I may go to for brake clearance ( alot of brake). It's the only reason I want 20's cause I'm not into bling.
There's a better chance I'll go w/. 20's than see a white zebra. Never heard that one...white zebra.
I don't think it was the wheels as much as the 285s on all 4 corners. The 285s dwarf the stock tires.
GMCtrk is offline
Old 11-20-2010, 04:51 PM
  #22
PT's Slowest Truck
budhayes3's Avatar
Get some lightweight Centerline 20's and you'll probably gain in the power and efficiency department. The Centerlines that I was window shopping last night were all between 24 and 28 pounds for chrome or polished aluminum 20's...wish I had the dough Now my Gibbs 20's on the other hand...they're like having 4 round anchors in the corners, makes a big difference in the braking performance also.
budhayes3 is offline
Old 11-20-2010, 04:55 PM
  #23
GMCtrk's Avatar
the Centerline's are lighter, I weighed the Escalade's and they were 28lbs each.
GMCtrk is offline
Old 11-20-2010, 04:57 PM
  #24
PT's Slowest Truck
budhayes3's Avatar
Yea, besides being wider they're about an inch and a half taller...about 3/10" taller than my 285/50-20's
Old 11-20-2010, 05:01 PM
  #25
PT's Slowest Truck
budhayes3's Avatar
Yep, that's pretty much the point that I was trying to make....I like the Centerline Ultra Series "Voltage", it's a 5 spoke and weighs 24 lbs in either chrome or polished. I like polished but it's a bitch to maintain...chrome is easier but costs $150 more per wheel! (I can't afford em either way, but it's nice to dream )
Old 11-20-2010, 07:47 PM
  #26
denali_on_26's's Avatar
Location: Where our street cars are faster than your racecars..Mississippi
i plan on having moser redrill my axles and rotors including front and running 15x4 and 15x10 centerline revs on the regular cab turbo truck.....
denali_on_26's is offline
Old 07-18-2017, 12:21 PM
  #27
Mark Johnson's Avatar
So what will I be looking at from an LQ4 with 243/ 799 heads compression wise..........
Mark Johnson is offline
Old 07-18-2017, 02:17 PM
  #28
03sierraslt's Avatar
I think they are 64cc stock so add .7cr to the Lq4's 9.4 and it should be around 10.1 with the same gasket.
03sierraslt is offline
Old 07-18-2017, 06:09 PM
  #29
Wow- would add some notable zing over the ole LM7...........
Old 07-18-2017, 06:25 PM
  #30
Ya, a 10-1 6.0 with a mild cam would be very noticeable.
Quick Reply: LQ4 with 706 heads = more power AND mpg????
