LQ4 with 706 heads = more power AND mpg????
Location: Where our street cars are faster than your racecars..Mississippi
i have a stock 2005 lq4 in my crew cab 1500 only thing done to it is longtubes and ORY and a RWTD tune...
what would the compression be if i used stock gaskets and milled a set of 706 heads .025? and do you think the power would be worth changing to the heads? and also do you think the MPG's would go up or down drivin the same way i drive it now (17 highway and 14 town)..
i will eventually put some type of cam (220 or 224) in it
they flow good enough for a daily driver THIS IS A CREW CAB ON 24's not a racetruck...
and also for $250 i can get them milled and the valves from a 317 head installed into them for a little more flow...
dont due it man ! yes the compression will go up with 706 but the top end flow will drop like a sack of potatos! i went that route and know i have to speend cash again just to get some better flowing heads ! if you can get the bigger valves then thats cool! but you can probable get some 799s or 243s for an extra 100 bucks and they already have bigger valves and the flow better as it is becouse its a better cast then the 706s! dont due it!
243 heads
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 64.45 cc-------0.100---0.200--0.300--0.400---0.500---0.550---0.600
Intake 210 cc------------62------126----184----224-----251----256----257
Exhaust 75 cc------------57------108----143----163-----176----180----183
706 heads
Intake Valve Diameter: 1.89 inches
Chamber 61.15 cc----0.100--0.200--0.300-- 0.400--0.500---0.550---0.600
Intake 200 cc----------63 ---128----179-----210----218----221-----226
Exhaust 70 cc----------54 -- 93 ----121----145-----163----168----174
317 heads
Chamber 71.06cc----0.100---0.200--0.300--0.400--0.500--0.550--0.600
Intake 210cc-----------66-----142-----196---228----236---238-----240
Exhaust 75cc----------59-----104-----137---155----167---173-----177
with that being said... I PERSONALLY think the ONLY difference between the FLOW of a 706 and a 317 is the valve size ONLY....CORRECT???
706 heads
317 heads
PT's Slowest Truck
243 heads
706 heads
317 heads
706 heads
317 heads
