LQ4 with 706 heads = more power AND mpg????
Old Nov 20, 2010 | 03:32 PM
fastnblu's Avatar
Where'd ya get those specs? Stock from GM catalog, correct?
Interesting seeing what flows where on different heads? Some surprises.
Also, 317 & 706 are different in terms of CC's. Denali on 26's take a look at the very info u posted.
Another thing, if concerned on MPG's & you're thinkin heads, & a cam, do a cam swap & you'll see how much you'll lose there. I know I lost a bit.
But I gained in a different way.
Old Nov 20, 2010 | 03:37 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
found it on this website...BUNCH OF GOOD INFO THERE THE LINK IS BELOW
https://www.performancetrucks.net/fo...d.php?t=434396
i'm not looking on the .600 lift cause i'm not gonna go much over a .550 lift as well...
Old Nov 20, 2010 | 03:42 PM
budhayes3's Avatar
PT's Slowest Truck
Great info there...good job searching too
Old Nov 20, 2010 | 03:44 PM
fastnblu's Avatar
I remember that thread. FastBrick knows his ****. I think a Mod was supposed to do a casting sticky.
Yes, I wasn't implying to look at look @ .600 lift. Or only that. I could be wrong, but (Billy) don't u wanna have good flow #'s at the lift your cam is at? The 243's & 317's have better flow #'s, along w/. those bigger I&E valves, while the 706's have the smallest chamber of all. I noticed the 243's are nestled almost in the middle of the two in terms of chamber size.
Old Nov 20, 2010 | 04:04 PM
its what happens when your girlfriend is cleaning your truck and she breaks one of your valve stems on a 24" wheels and ALL the wheel shops are closed till monday
Old Nov 20, 2010 | 04:07 PM
O'yea...
also i have somewhere between 3-7 sets of 706 heads on core motors i have swapped out for people... is the reason why i am leaning towards the 706's
what would my compression be with stock gaskets and the 706's with 58cc chambers?
Old Nov 20, 2010 | 04:22 PM
GMCtrk's Avatar
You're chasing a white zebra with those 24" wheels and MPG.
I know when I went from factory 255/70/16 to 285/60/18 I was shocked at how much power it sapped. I can only imagine going from 16s to 24s.
Old Nov 20, 2010 | 04:30 PM
only chasing "better" MPG
and i can't afford to be a fast 4door BUT i can afford to be a semi quick 4door on 24's...
Old Nov 20, 2010 | 04:33 PM
GMCtrk's Avatar
just put a turbo on it...that should do the trick
Old Nov 20, 2010 | 04:38 PM
fastnblu's Avatar
18's made that big of a diff. for you? That kinda ironic, 18's or maybe 20's are what I may go to for brake clearance ( alot of brake). It's the only reason I want 20's cause I'm not into bling.
There's a better chance I'll go w/. 20's than see a white zebra. Never heard that one...white zebra.
