!!!Lose of oil pressure after cam swap
Old 04-28-2018, 06:43 PM
Registered User
Johnstewart's Avatar
Default !!!Lose of oil pressure after cam swap
So I have a 04 avalanche with the 5.3 I did a stage 2 btr cam and have lost all oil pressure at idle. What is going on? Is it the cam bearings? Will it come back if I put the stock cam back in? Before the install I had good pressure. I have checked the pick up o ring. I changed the pump. New pan gasket. And checked it with a oil gauge. I have been told that it is probably the cam bearings. What do I do?
Old 04-28-2018, 06:47 PM
arthursc2's Avatar
Received 1,434 Likes on 1,062 Posts
Did you install the thrust plate?
Is the gasket on it good?
look there. Cam bearings don't dictate oil pressure, that's mains. Cam bearings might have a little to do with pressure, but the mains dictate it
Old 04-28-2018, 06:54 PM
Registered User
Replaced the plate gasket 2 days ago with the pump. Same problem
Old 04-28-2018, 07:00 PM
Registered User
Fyi, it idles at 15 on start up but drops to 5 when warm. The warn chim kicks in when this happens. If I rev it I see 25psi
Old 04-28-2018, 09:27 PM
chevysten's Avatar
Make sure you installed the correct o ring. It should have been the green one !!
Old 04-29-2018, 06:36 PM
Lowexpo's Avatar
It’s not cam bearings. I didn’t know you could get a gasket for retainer plate? I replaced my cam retainer plate. That’s what was causing mine to not get pressure when prelubing engine. The oil pump o ring is probably the issue.
Old 04-29-2018, 09:37 PM
jake 03's Avatar
In an ls motor cam bearings do dictate oil pressure. If you have a bad one the engine will not have oil pressure.
Old 04-30-2018, 11:16 AM
11 Second Club
MrHorsepowerLSx's Avatar
Both will have an effect on oil pressure when worn but more commonly cam bearings wear before mains and cause oil pressure loss
Obvious issues are pump and o-ring but if repair isn't found with them suspect cam bearings
Old 04-30-2018, 03:27 PM
madmann26's Avatar
Ask crashmymax what to check. Lol
seriously, check the backing plate oring or just replace it....it’s cheap.
You mentioned you replaced the pump? Did you preprime it? There is a plug on the side of the motor just for this. YouTube it.
Correct oring on the dipstick tube?
Did you mess with the galley plug to the right of the pump? Crashmymax’s builder did this to him. Check it.
No reason to check the barbell unless you pulled it out through the front of the engine, but then you would have bigger issues.
Old 05-02-2018, 12:59 AM
B00sted2007's Avatar
Honestly man the pickup tube oring, faulty oil pump, or camshaft retainer plate makes the most sense. If all you did was a cam swap and install a new oil pump, and you had good oil pressure before the cam swap, then it’s gotta be one of those three things! Cam bearings don’t go bad from a cam swap, unless you knocked one out when you installed the new cam! Lol
what oil pump did you use?
do you have a micrometer? Hell I’d check the measurements on my stock cam circle and compare the measurements with the measurements off the cam you put in, maybe something got dicked up on the overall diameter of the circles thatvride on the cam bearings on the new cam you installed? Long shot, but I’d measure them!
Blackout-88 (05-10-2018)
Quick Reply: !!!Lose of oil pressure after cam swap
