Lifter Preload
Old Mar 18, 2011 | 06:06 PM
dirt track racer 81's Avatar
Alright so if I tighten the rocker down and then adjust the checker to 0 lash. Take that measurement and say I want .070 preload, add .070 to the checker and if the valve still opens, that's ok?
They guy I bought them from said they were new Comp oe lifters.
Old Mar 18, 2011 | 07:11 PM
Gadgetized's Avatar
No, the valve can't be opened at all. Do you still have the valley cover on? I think you are pushing the cup down in the lifter, and not knowing it. It doesn't take much pressure at all to push it down when there isn't oil in it. I was actually thinking of doing a write up for this stuff.
Old Mar 18, 2011 | 07:29 PM
That's what I'm wanting know that the valve should not be opening at all. Intake and valley cover are still on.
With the rocker tight, at 0 lash (no up and down movement but side to side and pushrod can spin) the checker comes out at 7.317. Since I had a 7.35 pushrod that gives me .033 preload correct? With a 7.35 pushrod my valve opens with the lifter on the back side of the cam.
Old Mar 18, 2011 | 07:47 PM
Gadgetized's Avatar
Yes that is correct. Did you spin the engine over by hand at all? When I got my lifters the cup was stuck in most of them until I loosened them (I just turned the engine over). Do you have an old lifter still? The cup should move quite a bit. Your new lifters should move the same (or pretty close).
Old Mar 18, 2011 | 07:57 PM
I've put about 3k on these. The cups can move in. Like I said before adjusting the pushrod length checker to were I can get over .020 preload in them the valve will open. Yes I'm turning the motor over by hand..
Old Mar 18, 2011 | 08:03 PM
Bumpers's Avatar
My checker lenth was wrong on mine.. it was suppost to be 6.125 iirc and it measured 6.138.. So I went off the measure ment I got.. But I just measured to what I believe zero lash is and ordered my pushrods or the closest one.. I should have .075 preload but I have ls7 lifters.. I hop I did mine right.. It runs fine and not too noisey so I guess its good.. Can't really hear anything over the damn double springs haha. It was a pita.. I did it like 4 or 5 times just to make sure I got the same lenth everytime
Old Mar 18, 2011 | 08:09 PM
I've checked it several times and I'm measuring with a micrometer. Thinking about just getting ls7 lifters.
Old Mar 18, 2011 | 08:13 PM
Bumpers's Avatar
The main thing is I would measure your checker to make sure the exact measurement on it
Old Mar 18, 2011 | 08:55 PM
Yea I'm checking the length with a micrometer.
JordanH
Nov 6, 2015 07:42 PM
gmcyukon
Oct 5, 2015 06:20 AM
santoy956
Sep 10, 2015 03:12 PM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
