L92 Springs LS7 cam
Old Jun 22, 2008 | 11:57 PM
ChevyTruck's Avatar
something else
Question L92 Springs LS7 cam
I am looking into getting a LS7 cam for my 5.3 silverado, and a set of L92 springs also. My questions is will the cam and the springs fit on my truck?
The specs for the cam are:
Camshaft Duration:
211 degree intake / 230 degree exhaust
Camshaft lift (in):
.591" (15 mm) Intake and Exhaust
I am not that good with this part of motor work but i am trying to learn i have some info that i have recived from some members. so is that a good cam spec.
Old Jun 23, 2008 | 12:25 AM
00ChevyScott's Avatar
Wearin' da big hat
why are you wanting to put an ls7 cam in?
Old Jun 23, 2008 | 12:26 AM
RandomHero's Avatar
Terrible cam in my opinion for a 5.3L n/a truck. Not to mention you have a gen III motor and the ls7 is a gen IV motor. The cam position sensor among other things will be an issue. You will be much much better off getting a custom grind or at the very least get an 01-03 ls6 cam.
Old Jun 23, 2008 | 12:31 AM
ChevyTruck's Avatar
something else
thanks everone so far. like i said from the getgo im new to the internal motor work. that is why i have turned to performancetrucks.net for some advice and help.
so haveing a custom grind cam is the best way to go?
Old Jun 23, 2008 | 12:47 AM
ChevyTruck's Avatar
something else
does any know the specs on the L92 springs?
Old Jun 23, 2008 | 02:33 AM
AdioSS's Avatar
12 Second Club
and for what it is worth, that valve lift is with the LS7's offset 1.8:1 ratio rockers, not our stock 1.7:1. Plus the lobe seperation angle is VERY wide.
Old Jun 23, 2008 | 04:51 AM
7845's Avatar
Banned
L92 springs arent meant for performance. look into the new 918s or PRC duals
Old Jun 23, 2008 | 08:57 AM
OnyxSilveradoSS's Avatar
I have a set of L92 springs and will try to test them. let me know if you want them
Old Jun 23, 2008 | 01:01 PM
zippy's Avatar
The cam would take more work than it's worth. The L92 springs should fit, but I wouldn't use them in a high lift setup.
Old Jun 23, 2008 | 03:19 PM
joshluther's Avatar
Spring specs
https://ls1tech.com/forums/showthread.php?t=691832
