Knock sensor stuck spinning nbs 99-06 v8
Old Jun 25, 2016 | 07:01 PM
Luis3701's Avatar
Default Knock sensor stuck spinning nbs 99-06 v8
I recently had to swap out a knock sensor but when I was taking them off they just kept spinning on the top without them coming off . I finally got them off but when I put the new one in it starting spinning after tighnening them and the check engine light code came on for that knock sensor . Has anyone ever encountered this or know a way to prevent it?
Old Jun 26, 2016 | 09:57 AM
Wolftrk99's Avatar
Sounds like you need to run a tap down into the hole and clean the threads of the loctite/corrosion that is in there... If the top of the sensor starts spinning in the body it needs to be replaced, if youre lucky it will twist the internals and still read butbthe top being loose with give you false knock, if not so lucky it breaks intermally and gives you a circuit code
Old Jun 26, 2016 | 11:03 AM
1FastBrick's Avatar
Custm2500's Rude Friend
They have a specific torque spec and if you do not torque to that spec it can crush them and damage them.
I believe the torque spec is 15ft lbs. on the knock sensor
Old Jun 26, 2016 | 11:04 AM
Wolftrk99's Avatar
Is it that much? I thought those were like 106in/lbs??!!
MikeD.
May 7, 2016 11:55 AM
Furdkiller
Apr 28, 2016 12:26 AM
Furdkiller
Apr 21, 2016 12:30 AM
40series
Apr 14, 2016 02:51 PM
Rockgirl4life
Apr 1, 2016 12:25 AM
