just thinking ahead-need opinions
Old Apr 15, 2006 | 05:10 PM
greentahoe's Avatar
A T trim fits the S trim bracket, but I seriously doubt you'll see 15# on a 408. 2 reasons first the blower isnt that much bigger or efficient although it is an improvement. Secondly, there is no way you'll be able to get a belt/pulley/tensioner setup that will spin it close to fast enough.
I never had the T trim on my truck, but I do know that you'll run into problems with the aftercooler running higher boost on a T trim.
Im considering having my 6.0 made into a 370 due to the downtime Im facing currently as well. I think the smaller stroke is preferable when you are wanting big boost, of course I havent seen anyone with 408 having problems with the longer stroke.
Anyone know what size pistons and rods?? Im thinking I should keep my eyes open for a deal. Any specifics on the pistons I should look for? 4.030" bore and a 3.622 stroke ??? What length rods?? What do I look for??
Old Apr 15, 2006 | 05:33 PM
2004SSS's Avatar
hmm 370 or 408 , the 370 would be cheaper since i could use the stock crank, i may stick with the strim for now because the carb legal thing. as for the aftercooling i have a little bit covered i have this for a heat exchanger,
and i could always add a bigger coolant reservoir.the t-trim will be probably be the last step, i just need to get a 4l65e to handle this .
Old Apr 15, 2006 | 05:41 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
that is the trick, too bad you cant get an 80e
Old Apr 16, 2006 | 09:53 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Give Chuck at FLT a call.
Old Apr 16, 2006 | 08:10 PM
2004SSS's Avatar
i wonder if the 6.2l block would be a good choice for this?
southernsmoker
Aug 31, 2015 03:09 PM
urdone
Aug 18, 2015 12:17 PM
2500ZL1
Aug 14, 2015 12:23 AM
Aboss
Jul 9, 2015 10:28 AM
Ajaay
Jul 8, 2015 09:29 PM
