just thinking ahead-need opinions
Old Apr 13, 2006 | 02:14 PM
2004SSS's Avatar
Default just thinking ahead-need opinions
well i currently have a stock 6.0 lq9 with the vortech v2 sq trim blower set up, i also have a futral cam 213-219-15 +3with the comp 918 springs and ti retainers.I also have a spare 6.0l block sitting here.The question is what should i do with it? I would really like big cubes 402 or 408 but i dont know if the vortech will be able to feed it.ANother idea is just bore it .30 over and get some forged pistons/rods. to accomidate more boost, i think that would give me a 370.
So if you guys would put yourself in my shoes what would you do? T.I.A.
Old Apr 13, 2006 | 02:38 PM
LS1TRUCKGUY's Avatar
NOT TOO FAMILIAR WITH THE VORTEC S/C'S, BUT CAN YOU RUN A DIFFERENT PULLEY FOR MORE BOOST? IF SO, I WOULD BUILD A 408
Old Apr 13, 2006 | 04:28 PM
Quik's Avatar
5 year bitches!
10.1 CR and alot of boost, um probably not a good idea
Old Apr 13, 2006 | 05:02 PM
2004SSS's Avatar
well if i am going to rebuild the motor im going to do arorund 8-9 to 1 compression and then up the boost to around 15 psi or maybe a bit more. i am just unsure of this vortech being able to push that kind of boost with those cu in.
Im trying to keep it so it will still pass smog though, just seeing what my options are
Old Apr 13, 2006 | 06:19 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I'm not sure what teh V2 SQ will support, but I'm sure you can get a Vortech to feed a 408. It might be a huge pia to mount, but...
Old Apr 14, 2006 | 01:36 PM
2004SSS's Avatar
why is that, wont the engine be about the same size? except the new heads ?
Old Apr 14, 2006 | 05:03 PM
I AM A MOTHERF*CKER
Yeah but ussually the blowers big enough for the cubes are "race" and don't have kits. I may be wrong there, but that's how it is for ATI.
Old Apr 14, 2006 | 08:18 PM
2004SSS's Avatar
well i already have the vortech in my truck. so i dont think it will be a problem, they even have an upgade( t-trim) for it that will bolt right up and its more efficient!! i think a 408 will be in the not so distant future!
Old Apr 15, 2006 | 04:59 PM
I AM A MOTHERF*CKER
My suggestion would be to talk with the Vortech guys and make sure one of those two blowers can feed a 408. If not, they can tell you which one you need and how hard it would be etc.
Old Apr 15, 2006 | 05:08 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
view sig for my opnion
