Intake Manifold ?
hi all ,,
i searched all the net and didn't found any result of Intake Manifold for the 4.8?
or they didnt made any Intake Manifold for the 4.8L ?
did any one know where to find Intake Manifold's for the chevy ,
4.8,
5.3,
5.7
6.0 ?
and thnx
4.8,
5.3,
5.7
6.0 ?
and thnx
seriously??
the 4.8, 5.3 use the same intake.......let me find you a HUGE thread comparing all the intakes....any ls1 intake from 99-07 will fit your 4.8...any ls6, ls1, or truck intake... they have the same bolt patterns...only some have a different style fuel rail/coil layout.
https://www.performancetrucks.net/fo...d.php?t=397720
here you go man, kick back and read for a while.
no prob BOB...
just keep in mind, almost EVERYTHING will interchange between these motors, from a corvette z06, z-28, 4.8, 5.3, 5.7, 6.0..... they are all ls1's and use similar cams/heads/intakes..... some stuff requires mods to make fit, but most will swap over...
your motor is what we call a gen iii ls1 ( gen 3 )..... so if you do a parts search, almost anything you find for a gen iii ls1 will fit your 4.8. ;-)
i read it i didnt understand well in numbers and parts
so can u help me with it ?
i need a good Intake Manifold for high rpm and with 220\220 cam on 4.8L
whats the Intake Manifold would be great for it ?
so can u help me with it ?i need a good Intake Manifold for high rpm and with 220\220 cam on 4.8L
there are threads all on here about doing the ls6 manifold swap... use that search tab in the GM ENGINE & EXHAUST forum....
a 220/220 is going to run out of power before it revs "high"...at around 6300-6400
i couldnt see a need for an intake swap? but if you must, the fast 90/90 is a good upgrade, along with a 224-230 duration, high lift cam, and all other supporting valvetrain upgrades to rev high....
how much is "high"..... 7,000..... 7500?? we have revved a forged 283 to 9500 rpm.... i call that "high"... just depends what you want bro.
