Intake maifold probs
Old Sep 3, 2007 | 10:50 AM
maxpwr21's Avatar
Registered User
Post Intake maifold probs
This is the problem,I want to eventually run forced air on my '98 L31 5.7. The stock intake with 19lb hour injectors and the way they run inside the maifold is a limiting factor, I have heard that either a marine intake or a Ramjet intake setup would solve my problem. I need to know if either of these will solve my problem and if they will plug right into my harness. Also any sugg as to where to purchase... thanks guys.
Old Sep 3, 2007 | 11:07 AM
moregrip's Avatar
what a rush!
James B. is the guy you want to talk to:
https://www.performancetrucks.net/fo...d.php?t=384742
Old Sep 15, 2007 | 12:39 AM
hog's Avatar
hog
I am running EV6 injectors in my marine intake. They flow 24pph at 43.5 psi which actually flows 28.3pph at the vortecs 60 psi of rail pressure.
Here is all the info.
marine intake
http://www.pacificp.com/forum/viewtopic.php?t=317
a twin turbo ramjet intake with GEn 3 411 PCM.
http://www.pacificp.com/forum/viewtopic.php?t=3240peace
Hog
Old Sep 15, 2007 | 03:16 PM
TarheelZ's Avatar
Default Hog!
I haven't seen you around here in forever...welcome back! I've wondered where you've been?
chvy=power
Oct 20, 2015 09:08 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
turbo truck
Sep 2, 2015 09:58 PM
lxcoupe
Sep 2, 2015 12:58 AM
