installed ls6 springs, doesnt sound right
Old Apr 22, 2006 | 03:35 AM
adrenalinep's Avatar
Default installed ls6 springs, doesnt sound right
installed them and when started, it clattered a little which i think is normal but then was making a loud ticking noise. Do the rocker arms need to be torqed to ls6 spg specs any help please
Old Apr 22, 2006 | 11:35 AM
sliderbkt's Avatar
Did you rotate the motor and retorque to spec. If not you may just have one or two a little loose.
Old Apr 22, 2006 | 11:51 AM
99Silver6.0's Avatar
Rotate it 3-4 times and TQ them to 22 ft-lb's. Possible one is loose.
Old Apr 22, 2006 | 01:20 PM
Took valve covers off and two of the rockers are loose I did rotate it 360 then torqed . Do i need to rotate more times ?
Old Apr 22, 2006 | 01:33 PM
If 2 were loose I would roll it a couple more times and re-tq.
Old Apr 22, 2006 | 01:43 PM
So I rotate and torque till there is no play in rocker arms . thanks for help man
Old Apr 22, 2006 | 02:37 PM
Just TQ them a few times after rotating the motor over. You dont have to do it over and over.
www.ls1howto.com outlines the task very well!
ARC
57
Feb 21, 2022 10:54 AM
lxcoupe
Jul 30, 2015 02:42 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
