Building a Low Comp 5.3
Old Apr 21, 2006 | 12:42 AM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
Default Building a Low Comp 5.3
Well let me start off by saying that im going to have a lot of questions since i have never built a motor from the block up.
I am getting a 5.3 block that has been bored .030 over for a very good deal. I am going to be building this up as a low compression FI motor. I believe that i will use a stock 5.3 crank because they seem to hold up just fine. One thing im not sure about is the piston size. I do not know the stock 5.3 bore or what is is now that is has been bored out .030 over. So i need to know what size piston to go with.
I also belive that the stock rod length is 6.125" so i can just get a good forged rod with those measurements since im keeping the stock crank.
I need to know more about compression on this motor. I would like for it to be around 8.75:1 or so. I plan on using some 317 heads and i believe the combustion chambers on those are 72cc, so i need to figure out the dish(or no dish) on the pistons as well as the head gasket thickness.
I have many more questions but this will be a good start.
Thanks,
Mark G
Old Apr 21, 2006 | 12:47 AM
BeefTip's Avatar
Also, what would the displacement be with the new bore, in the 330s or something..Please dont tell me that i have to get custom pistons.
Old Apr 21, 2006 | 12:56 AM
BeefTip's Avatar
I did some calculations real quick(have no idea if they are right) but I believe that a 5.3 over .030 would come out to be 3.809.
Old Apr 21, 2006 | 01:17 AM
PappyDan's Avatar
Tribe Shaman
you will have to special order a set of pistons.
any thing available that you can just order for a 30 over bore will give you a
low 9 on comp, that's with the 917 heads and gasket of chouse.
to get in to the 8's your looking at a custom set to be made for the 5.3
Old Apr 21, 2006 | 07:45 AM
BeefTip's Avatar
are you saying that ill have to order a special set no matter what compression I decide to go with, ill be happy with low 9s if i could pick up a set off of the shelf.
Old Apr 21, 2006 | 08:45 AM
FarmerBeau's Avatar
Sexy Party Mod
might wanna just jump up to 5.7 bore. It would be cheaper on pistons.
Old Apr 21, 2006 | 01:15 PM
BeefTip's Avatar
is that bore 3.90, also, how much is it to get them bored out like that.
Old Apr 22, 2006 | 12:26 AM
PappyDan's Avatar
Tribe Shaman
same price to punch out a block, does not matter if your going 010, 030, or 090.
Old Apr 22, 2006 | 10:26 AM
BeefTip's Avatar
yeah i just didnt know how much it was to bore it out, the block im getting is already been machined, i was also curious how much these 5.3 blocks could be bored out.
Old Apr 22, 2006 | 10:17 PM
PappyDan's Avatar
Tribe Shaman
you can turn a 5.3 in to a 5.7 if you had a good used set of LS1 pistons.
USMCvet0311
Aug 14, 2015 10:28 PM
Ammadien
Jul 22, 2015 08:50 PM
4B11T
Jul 13, 2015 03:48 PM
Aboss
Jul 9, 2015 10:28 AM
07NBSChevy
20
Jul 8, 2015 07:27 PM
