injector size
That's why I'm wondering if bolting in these 5.3L injectors that my motor started with is a bad idea. I don't plan on being at WOT very often except maybe on weekends to dig myself out of a mud pit or soggy trail and even then I don't let the needle ping off the red line.
we are not building stock 5.7 motors.
8.1 injectors or higher, change out the fuel rails, and an after market regulator that can be set.
the 8.1 truck or the marine injectors are a direct swap as far as fit. all you have to adjust is the tune. i would bet you could probably squeak by with your stock ones after looking at your build inchup. especially sice you won't be seeing much full load high rpm's.
Stainless Works
13
Nov 5, 2015 03:31 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
