I need some hard info 317s vs. 243s
Old Nov 26, 2008 | 12:57 PM
skyhighsami's Avatar
no title here
Default I need some hard info 317s vs. 243s
I have read and researched this topic and have read some info and I want to put this to bed for good. From what I have read these two heads are alike in everyway except the combustion chambers. The 243s being 62 and the 317s being 72cc. I have also read that the 317s have longer runners that aid more in low end tq. The plan is to mill some 317s to a 64cc chamber and port/polish the intake and exhaust, unshoud the valves, and a 3 angle job on the valves. Someone break down exactly the differences between the two, not what you think but some hard data to back it up. What I have read might be wrong but I am trying to have a matched combo. Thanks
Old Nov 26, 2008 | 01:02 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
243's are a 64cc chamber.
Old Nov 26, 2008 | 01:17 PM
gtosilverado's Avatar
what are u plannin to do with them ? what engine are they goin on ??? need more info
Old Nov 26, 2008 | 01:38 PM
tdrumm's Avatar
check out the ls1 page on smokemup dot com. They have the Genn III head specs there - flow #s, valve sizes, port volumes, chamber volumes, all by casting number.
Old Nov 26, 2008 | 03:24 PM
no title here
LQ4 iron block with LS2 rods and pistons with the standard crank, 220/226 cam .605 I .600 E on a 112 LSA, 10.7-1 CR, TBSS intake, and either 317 or 243 heads ported. 317s will be milled to yield a 64 cc chamber. I will be shifting at 6200 with a 6500 rpm redline. The stall will be a 2500 in my 1500 HD. It has a 4L80E and a 14 bolt with 3.73s. I want as much lowend torque and midrange.
Old Nov 26, 2008 | 09:21 PM
no title here
Anyone else have any input? I would like to get as much info as possible. I looked at the above link and didn't see what you were talking about
Old Nov 27, 2008 | 10:32 AM
Coban's Avatar
http://www.smokemup.com/tech/ls1.php
Old Nov 27, 2008 | 06:27 PM
no title here
The only thing that says is that the valves are lighter on the 243s and they out flow the 317s stock.
Old Nov 27, 2008 | 06:51 PM
skeet's Avatar
n/m me lol been drinking a bit today lol
Old Nov 27, 2008 | 09:52 PM
GMCtrk's Avatar
I don't think you can mill the 317s that much. I think you can take them down to about 68cc. Personally I would go with the 243s.
