I need help lol. ( new to this ) don’t bash me.
Old Mar 15, 2018 | 01:26 PM
Juiceman1989's Avatar
Registered User
Default I need help lol. ( new to this ) don’t bash me.
I have a 2009 “ police pursuit “ Tahoe with the 5.3. I’ve recently installed the Brian tooley DOD delete. Ls6 valve springs, lS7 lifters, stage 1 truck cam, new oil pump, valve seals, changed the 1 bolt cam gear to the 3. Truck started and ran for a little while & once shut off when hot it doesn’t want to start again. ( I figured it was a tuning issue ) I bring it to the tuners he throws a base tune on it to get it to run so he can put it on the dyno & it won’t start for him. He checks for codes and is getting a cam pos sensor code. ( currently he’s ordering a new sensor for it ) everything seems mechanically correct & I might be jumping the gun it could just be a bad sensor but does anyone have any knowledge on this ??? Please help lol.
Old Mar 15, 2018 | 02:32 PM
twin64's Avatar
Did you use a new front cover?
Old Mar 15, 2018 | 07:30 PM
Registered User
i used the cover it came with if I’m not mistaken well ( my mechanic did )
Old Mar 15, 2018 | 09:08 PM
arthursc2's Avatar
Cam sensor is too far away if that's the case
Old Mar 16, 2018 | 06:41 AM
twin64's Avatar
You need the LS3 front cover. Did you order a VVT delete kit also or just the DOD kit?
Old Mar 16, 2018 | 11:13 AM
B00sted2007's Avatar
Why would he need a new front cover? I’ve done numerous AFM/DOD deletes and never once had to change front covers.
Old Mar 16, 2018 | 11:24 AM
twin64's Avatar
I probably assumed wrong in the fact that he went from a single bolt cam to a 3 bolt cam that he deleted VVT also, in which case he would need a different front cover. I guess the better thing to ask would be if the cover/sensor/and cam gear are all correct to work together. Example being a 4x sensor and cam gear with a ls3 front cover.
Old Mar 16, 2018 | 07:46 PM
okay, I see what you’re saying; if the motor had vvt and he deleted the AFM/DOD without changing the front cover to a ls2/3 style, then yeah the cam sensor would not work when using a non vvt cam. The reason being, the vvt front cover places the cam sensor too far out from the cam gear.
Old Mar 16, 2018 | 07:50 PM
Registered User
Hey guys, I actually had the wrong cam gear, I had a 3 bolt 1x i switched it to a 3 bolt 4x and got it tuned it put down a little over 300HP to the wheels & 320tq but now I have a slight misfire and can smell raw fuel. Fuel pressure is good. Maybe one of the injectors got messed up while working on it? Should I replace the injectors ? I need all the help I can get lol.
Old Mar 16, 2018 | 08:02 PM
FFDP's Avatar
Replace the o-rings and check the line going to the rail.
You shouldn't be out flowing the injectors on a 5.3 being a 2009, they are fairly large for the size engine even stock. So replacing the injectors is kinda pointless.
