i did a search already...cam swap question
Old Dec 11, 2008 | 10:44 PM
viciousknid's Avatar
Where's the Beef?
Originally Posted by DozerDan
Cam
Push rods
Valve springs
New crank pulley bolt
~2 gallons of coolant
Red lock tite
2 5/16" dowel rods to hold the lifters up
Misc 8,10mm sockets and wrenches
Chrystler harmonic dampner puller
Valve spring compressor
AIR TOOLS ARE YOUR FRIEND
(Optional gasket kit, timing chain)
Is that about it guys?
Originally Posted by 06sierra5.3
i was a tech for a living, i have almost $20k in tools/box, im not paying anyone to do it.
i have a pretty good idea of what i need, but im not real familiar with GM yet, so i wanted to see if i was missing anything
thanks for all the help guys.
Everything Danny said. And you might as well get Water Pump Gaskets and Timing cove gasket. My timing gasket kinda tore so we had to patch it with RTV.
Re used valve cover gaskets.
Old Dec 11, 2008 | 11:27 PM
Phantom's Avatar
11 Second Club
Not saying its the best idea, but we haven't replaced a gasket or bolt on mine yet...been through 3 cam swaps. I guess we did recently replace the crank pulley bolt. It uh...disappeared during the last tuning session...which brings me to my next point. BE SURE TO REALLY TIGHTEN THE CRANK PULLEY BOLT
Old Dec 12, 2008 | 12:44 AM
06sierra5.3's Avatar
this will really help, thank you
even though it costs more, i ALWAYS replace gaskets when i dissasemble. one bad experience on my part, and a few other guys in the shop thats enough for me.
Old Dec 12, 2008 | 02:21 AM
LowBlack99's Avatar
Originally Posted by Go5.3tt06
Im curious where did you get valvespring tool from? Also the compressed air that what I been look for. Where did you get it?
The hose in the pic is just a basic compression tester with and air fitting put on to hook into a airline from a compressor. Cheap and easy way to hold the valves up if you have a compressor.
Old Dec 12, 2008 | 08:50 AM
eallanboggs's Avatar
The tool is from Vinci High Performance $100, but it is the best in the business. Don't waste money on any others. If you put the piston at TDC you don't need the compressed air hose since the valve can't fall that far, but if you use it for added insurance do use more than 50 psi if the plugs are out or the crank may spin. You can get away without changing most of the gaskets, but I never chance it with the crank seal on the timing cover. I use two 5/16" metal dowels to hold the lifters up while the cam is out. They are only used for the few minutes between the time the old cam is pulled and the new one is installed. This is an easy cam swap since the heads and intake are not removed. Good time to install an 25% underdrive pulley(ASP or Powerbond).
Old Dec 12, 2008 | 08:57 AM
TXsilverado's Avatar
ls1howto.com.
alot of the gaskets and bolts can be reused.
Old Dec 19, 2008 | 07:19 PM
RADO_4U2NV's Avatar
I agree. If you are goin to do something do it right. When I did my swap I did everything on the top end. Checked the valves to make sure they were good cleaned the heads (also easier to do springs with the head off). Would replace all bolts like I did as well. I did all ARP bolts. It is woth it for the peace of mind.
Old Dec 20, 2008 | 09:49 PM
budhayes3's Avatar
PT's Slowest Truck
I too don't believe in re-using gaskets, although many have done it without problems. Maybe if I was planning on multiple cam swaps and alot of testing, that would be different, but if I just planned on doing a one time cam swap, I'd replace all involved gaskets for some cheap insurance.
Old Jan 19, 2009 | 06:04 PM
z71_on_bottle's Avatar
Registered User
ive heard of using the 5/16 dowels but how do you do it...in the middle of cam swap on my 00 5.3 ecsb z71 right now...
Old Jan 19, 2009 | 06:42 PM
Where's the Beef?
http://www.ls1howto.com/index.php?article=23
about 1/2 way down it talks about the JPR Lifter tool method. same thing but with dowel rods instead.
Bumpers
Aug 4, 2024 09:44 PM
Stainless Works
Nov 20, 2015 08:55 AM
1bad2k
Aug 18, 2015 09:50 PM
oharajo
Jul 18, 2015 09:24 PM
NuckenFuts
Jul 9, 2015 08:45 AM
