how will this cam run
Old Nov 6, 2011 | 10:39 AM
ou812sm's Avatar
Default how will this cam run
I have a ly6(6.0) that the heads were milled .40 ths the compression should be between 10.5 to10.8 the cam I was going to use is compcams lsr 269 219/227 .607/.614 on a lsa 112 how will this run
Old Nov 6, 2011 | 10:58 AM
jrmchevyman's Avatar
That cam will run fine, with the intake side being under 220 it should make power everywhere. What converter are you going with and in what vehicle?
You need to match it up with a good aftermarket converter as well. Might want to get gears later on too, depending on what you already have and if you have a heavy truck with heavy wheels/tires.
Old Nov 6, 2011 | 11:02 AM
ou812sm's Avatar
I have a triple disc circle d 3200 stall for gears I have 4.56 gears and 35" tall tires
Old Nov 6, 2011 | 11:09 AM
ou812sm's Avatar
In a 2004 tahoe I'm looking to get torque to get it moving
Old Nov 6, 2011 | 11:27 AM
Coban's Avatar
I would check piston-to-valve clearance with that cam and milled heads. Just as a precaution.
Old Nov 6, 2011 | 01:14 PM
True that, only safe way is to measure.
Old Nov 6, 2011 | 02:27 PM
ou812sm's Avatar
Yes I will but how will run
Old Nov 6, 2011 | 05:45 PM
budhayes3's Avatar
PT's Slowest Truck
Once tuned, it should run really well with a fairly broad powerband, and will also work well with your Circle-D 3200. Do you have anything else done to the heads? I wouldn't let that .6xx lift go to waste, and get a nice port and polish or CNC job. If you have the dough, you should give Richard at WCCH a call and discuss your options
Old Nov 6, 2011 | 05:55 PM
ou812sm's Avatar
Well i have some light p&p done on the exhaust side
Old Nov 6, 2011 | 07:04 PM
364HC's Avatar
Banned
ly6 have dished pistons, its should be fine with that lift/lsa
stealthperf
34
Feb 14, 2016 11:35 AM
steves86ta
Jul 28, 2015 10:21 AM
lxcoupe
Jul 27, 2015 08:19 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
