How to up the CR in a 5.3
Old May 9, 2006 | 12:22 PM
tahoe's Avatar
Default How to up the CR in a 5.3
Hi All,
Witch method would be the best/cost effective way to increase the compression ratio on an othervise stock Tahoe 5,3?
The reason for this is to gain fuel econnomy, and at the same time some torque. I will be running on E85 so pinging/knock is not a issue.
I am aiming for around 11 to 1, or a bit more.
( With E85 the CR can be up to around 13.5 - 1 with out knock.
105 Octane )
Br//
Old May 9, 2006 | 12:47 PM
PappyDan's Avatar
Tribe Shaman
have the heads shaved, to bump it up more you could run a set of 4.8 flat top pistons.
Old May 9, 2006 | 12:51 PM
LS1TRUCKGUY's Avatar
Shave The Heads, Run A Thin Head Gasket. Thats The Easiest, Or Do Like Mentioned Above And Do The Pistons.
maxspeed05V
Sep 23, 2015 10:48 AM
nickrench3
Sep 17, 2015 08:48 AM
OVOAustin
Sep 15, 2015 08:32 PM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
