How to tell
Old Jun 3, 2006 | 09:48 AM
Default How to tell
the difference between lq9 and lq4 just bought a 6.0 and want to know. I know on the heads it has 317 stamped on it, but I dont know if that helps.
Old Jun 3, 2006 | 11:08 AM
onebadrubi's Avatar
get the serial number and take it to a gm dealership. Besides that You would have to look at the pistons.
Old Jun 3, 2006 | 11:23 AM
Colby 04's Avatar
pull the spark plug and look in there to see whether it has dish top or flat top pistons.
dish top = LQ4
flat top = LQ9
the dish top will have a little raised ridge around the outer edge of the piston. The flat top will be, well, flat, lol.
Old Jun 3, 2006 | 11:26 AM
TurboGibbs's Avatar
If the engine is out of the truck then pull a plug and with a flashlight look and see if it is a flat top or dish piston. LQ9's have flat-tops.
Here is a pic and info in this thread.
here
Old Jun 3, 2006 | 11:45 AM
Colby 04's Avatar
great find MJ
Here's a direct link of the pic
Old Jun 3, 2006 | 09:29 PM
03lowriderss's Avatar
sniff em you can normally tell an lq4 by the smell
Old Jun 4, 2006 | 10:17 AM
Colby 04's Avatar
I did the flash light in the spark plug hole trick on mine yesterday. It's a little hard to see, but I saw the dish tops on it.
Old Jun 4, 2006 | 10:51 AM
Rhino79's Avatar
9 Second Club
What year engine is it? I know the 99's have a wider flange at the back of the crank for use the the 4l80 transmission.
Old Jun 4, 2006 | 12:50 PM
Quik's Avatar
5 year bitches!
or look at the flexplate, LQ9 has a smaller bolt pattern and a LQ4 has a larger onesince one uses a 60/65 and other uses 80
Old Jun 4, 2006 | 02:11 PM
Colby 04's Avatar
will this affect the way the transmission bolts up?
I've got an LQ4 and will be bolting up a 4L60E to it(I know, I know, it will fail)...but is there anything I need to change up for that? Everything should bolt up, right?
