how often do u guys change ur valve springs
I had 70,000 miles on 918 springs with the 212/218 .558/.563 cam... I know they "relax" but wouldn't you feel real dumb if you changed them out and then the new set broke? It seems the infant mortality rate is much higher than the old age failure rate.
So I'm digging up this thread cause I've got 110000 on my springs. Comp 918's I believe. I've had a .581 lift cam in it for all those miles and just changed to a .596 lift. Its been rode hard and put up wet. You guys think I should change mine?
