How do you know if a crank needs to be turned?
Old Feb 24, 2006 | 11:40 AM
thunder550's Avatar
High on diesel fumes
Default How do you know if a crank needs to be turned?
I am selling my crank and have had a few people ask if it needs to be turned. I don't really know what that means or how I can tell if it needs it. Can someone explain?
Old Feb 24, 2006 | 01:56 PM
KySilverado's Avatar
Any evidence of wear-scratches etc on the crank or rod journals. Turning is milling these surfaces down, smaller journal diameter, to a correct clearance with bearings for proper oil pressure. Basically a good smooth surface for the bearing surface. You turn the crank down then put larger/thicker bearings in.
Hope that makes sense
Old Feb 24, 2006 | 07:50 PM
bluecajun5.3's Avatar
11 Second Truck Club
what ky said. also you can check the clearances with plastigauge. though i don't know what the specs are for the genIII motors.
Old Feb 24, 2006 | 09:35 PM
TurboGibbs's Avatar
What Ky and bluecajun said + using micrometers to actually mic the diameter and compare with factory specs and tolerance. Basically on most late models if it is a smooth surface without scratches that you can really catch a finger nail on you are most likely ok.
Old Feb 25, 2006 | 08:05 AM
if the journals need a little cleaning up, you can use emerycloth to smooth it out fine...
legerwn
56
Nov 15, 2015 10:21 PM
dantheman1540
Nov 1, 2015 02:59 AM
drummer0415
11
Oct 24, 2015 08:16 PM
FormulaZR
Sep 14, 2015 05:23 PM
Justin87gn
Sep 10, 2015 12:06 PM
