Higher compression using 5.3 heads on a 6.0
Old Dec 21, 2006 | 04:11 AM
eallanboggs's Avatar
Default Higher compression using 5.3 heads on a 6.0
Patriot tells me I can use my 5.3 StageII heads on a 6.0 motor, but the compression ratio will increase by a factor of 1 because the chambers on the 5.3 are smaller than on the 6.0L. Is there a head gasket out there that is a little thicker than stock that would give me a little more volume so I can use my 5.3 heads on a 6.0 without increaseing the compression ratio?
Old Dec 21, 2006 | 08:34 AM
thunder550's Avatar
High on diesel fumes
IIRC the stock ones are about .054 or so, and the thickest I have seen is a .06. Cometic makes a .06.
Old Dec 21, 2006 | 10:37 AM
the 6.0 bore is bigger than the 5.3 bore so wont the deck of the heads hang over the cylinder walls in a 6.0? maybe i'm crazy
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
Aboss
Jul 9, 2015 10:28 AM
