High lift wear on springs
Old Jul 7, 2020 | 04:35 PM
Jona91's Avatar
Default High lift wear on springs
I was looking to get a high lift stage 2 cam from Texas speed, but I read that the high lift will cause more wear on my springs, is this true? I have pac1219 springs.
Old Jul 7, 2020 | 05:42 PM
RedXray's Avatar
100% Redneck
Yes... aggressive lobe ramp rates also effect spring life.
Old Jul 8, 2020 | 12:00 AM
Jona91's Avatar
How long till they go bad?
Old Jul 8, 2020 | 04:21 PM
darkirish63's Avatar
My PAC 1258 springs on my AFR heads lasted about 60k miles and one refresh on the heads with my high lift came before 4 of them self destructed. Not bad, really.
Old Jul 8, 2020 | 06:29 PM
Jona91's Avatar
So if I go with the high lift. I'll be good to change them every 50k miles?
Old Jul 8, 2020 | 07:02 PM
What's the lift on that thing? Is it .629? Every 50k would be a safe interval if so.
Old Jul 8, 2020 | 07:35 PM
Jona91's Avatar
It's 212/218 .600
Old Jul 8, 2020 | 08:15 PM
It's 212/218 .600
112lsa? Those springs have a max of .625. You should be good with 50k+ . Still, to be safe I would pull a couple @ 50k to test tension against specs just to be sure.
bluebommer07
Apr 5, 2012 11:43 PM
Silvy6.0
Apr 16, 2009 07:57 AM
usarmyman
Aug 20, 2007 08:32 AM
JWRENCH
Feb 21, 2003 10:21 AM
