help on raising compression on lq9 6.0...
Old 06-26-2009, 01:19 PM
chris04's Avatar
Originally Posted by TurboBerserker
317 heads (stock LQ9) == 72cc (these are essentially 243 heads with different valves and bigger chambers)
241 heads (stock LS1) == 67cc
243 heads (stock LS6) == 64cc
An LQ9 with 317 heads is 10.1:1
An LQ9 with 241 heads is 10.7:1
An LQ9 with 243 heads is 11.1:1
thanks man, that helps alot,so this is based on using stock head gasket right? so now i need some 243's from somewhere cheap haha, so one more question could i mill the 243's lets say .20 if i wanted too...
Old 06-26-2009, 02:17 PM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
No problem.
Yeah that was all based on stock compressed height (GM MLS) gaskets.
For 243s, check out the Corvette Forum. Parts go cheap over there.
And yes, you can mill 243's. Patriot does 243's in 58cc chambers, so you've got plenty of room.
Honestly, though, I don't think you'll be able to tell any difference between 10.7:1 and 11:1.
Old 07-01-2009, 11:08 PM
jophuss36's Avatar
I'm not sure how much you can mill b4 causing PVC problems but I would definatly use a cometic .40 gasket but be sure to spray it with copper gasket spray to keep it from blowing that will help with quench and compression
Old 07-09-2009, 05:27 PM
AndysC3's Avatar
sorry to jack this thread, but quick question. How will the 243s do in a LQ4? thanks
Old 07-09-2009, 07:52 PM
1Bear's Avatar
In the book by Will Handzel, they dynoed an LQ4 which checked out as having an actual 9.25:1 compression ratio and then again with LS6 heads which bumped the compression ratio to 9.915:1.
With the stock 317's, it put out 337hp & 373ft lbs. With the 243's, it put out 355hp & 396ft lbs. So it basically gained 18hp & 23ft lbs from the swap.
Old 07-09-2009, 08:23 PM
hirdlej's Avatar
Buy my 60 cc 11deg heads for sale in the classifieds. You'll have more PTVC than you'll know what to do with
Old 07-09-2009, 08:35 PM
AndysC3's Avatar
ok so that with a TR224, along with a retune Ill be looking around 420HP or so.
Old 07-09-2009, 08:50 PM
AndysC3's Avatar
thanks for the offer but those are alittle out of my price range. Also Im just looking around until I get home from my deployment.
Old 07-10-2009, 07:21 PM
terravast4's Avatar
put some 5.3 heads on there 62cc. texas speed has some stage 2.5's for $1134 p&p with 2.02 and 1.575 valves.
Old 07-10-2009, 10:13 PM
hirdlej's Avatar
I would stay clear of the TSP heads and wait for something decent to come along before putting those on.....
Quick Reply: help on raising compression on lq9 6.0...
