Help please
Old Apr 1, 2018 | 01:31 AM
Novicebuilder's Avatar
Thanks smokeshow. So since I don’t have cats, would that be an issue? So you’re saying that the primary temps should be close to exhaust temps as in right at the tail pipe? That’s one place I haven’t checked. Idk what steady state means exactly. My handle is novicebuilder but can actually be translated into noob builder
Old Apr 1, 2018 | 04:55 AM
smokeshow's Avatar
Mod with training wheels
Those low temps would be an issue if you DID have cats. My point is you should ignore those temperatures and look elsewhere for the issue.
Old Apr 1, 2018 | 01:38 PM
I’ve never paid much attention to the temperature of the primaries/manifolds before but I figured I’d check with a temp gun to make sure. I had spoke with a guy from seriousHP down in Houston and he said he’d be concerned with any temp over 300. You could see signs of heat on the intake valves and the machine shop guy said he’s seen intake valves that “tulip” from getting too hot and it actually makes the valve longer. How hot have you seen primaries get smokeshow? I don’t have cats, would that affect temps upstream? Should I weld some in? I wiggled the injector wire and taped it in place like factory and put the blue clip in place and no change. I figure it’s like you say smokeshow, timing. I’ve heard that with an efficient motor you need less timing?
Old Apr 1, 2018 | 07:30 PM
smokeshow's Avatar
I can tell you this: the production engines I work on are permitted to operate indefinitely with exhaust temperatures at ~1700°F. When I say timing, I mean injection timing.
Old Apr 2, 2018 | 02:31 PM
I think you think I’m talking about a Diesel engine!
Old Apr 2, 2018 | 05:34 PM
smokeshow's Avatar
No...
Old Apr 2, 2018 | 09:11 PM
1FastBrick's Avatar
Custm2500's Rude Friend
What year is the truck?
Are you using Stock injectors?
Did you measure for push rods or just slap those in there?
Old Apr 2, 2018 | 10:01 PM
07 classic and yes I’m using stock injectors
Old Apr 2, 2018 | 10:02 PM
No I didn’t measure for pushrods
Old Apr 4, 2018 | 09:03 PM
I dropped the truck off at the shop today to get retuned and or looked at to see what I’m missing. Lord willing Ima find out what the deal is!
