help with my cam installation
#21
PT's Slowest Truck
As if you haven't already got enough good info, what I recommend to folks to make them feel better about using the lifter trays; is after you lock the lifters up into the trays, take a pushrod and push each lifter back down onto the cam to see how much pressure it takes to do so. If they fall back down when you barely touch them, well then I wouldn't be too confident in the trays holding them up. If it takes a fair amount of pressure, you should be ok. If you already have one magnet (most folks do), you can actually pull the lifters up into the trays a little further than what the cam lobes will, locking them a little harder into the trays. Just pull them up until the magnet breaks free from the lifter. Of course if the trays still seem like they don't want to securely hold the lifters I would find another method.
#22
I AM A MOTHERF*CKER
Offroadunleashed
07-20-2015 02:25 PM
all_individual
07-13-2015 11:01 AM
