help with my cam installation
Old Jul 3, 2009 | 09:09 PM
  #21
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by 1Bear
As if you haven't already got enough good info, what I recommend to folks to make them feel better about using the lifter trays; is after you lock the lifters up into the trays, take a pushrod and push each lifter back down onto the cam to see how much pressure it takes to do so. If they fall back down when you barely touch them, well then I wouldn't be too confident in the trays holding them up. If it takes a fair amount of pressure, you should be ok. If you already have one magnet (most folks do), you can actually pull the lifters up into the trays a little further than what the cam lobes will, locking them a little harder into the trays. Just pull them up until the magnet breaks free from the lifter. Of course if the trays still seem like they don't want to securely hold the lifters I would find another method.
That's some pretty good advice, takes the "Russian Roulette" somewhat out of the lifter tray method. Don't want to scare the OP, but I have read of the little magnet coming loose from the pen magnet and staying magnetized to the lifter causing the head to have to be removed to remove the magnet...make sure that you get decent pen magnets.
Old Jul 3, 2009 | 11:49 PM
  #22
TurboBerserker's Avatar
I AM A MOTHERF*CKER
That's excellent advice :thumbs:
all_individual
Oct 10, 2015 10:09 PM
low2001gmc
Jul 23, 2015 05:10 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
ssierra08
Jul 15, 2015 06:40 AM
all_individual
Jul 13, 2015 11:01 AM
