Help me build my F/I 6.0
#24
Destroyer of Transmissions
What number did you use for the LS9 compressed thickness in your CR calc?
9.1:1 is fine if you are going to throw a bunch of boost at it. I think AK was saying to go higher so it doesn't feel like a turd DD out of boost. However, in a RCSB you will probably still be fine. I went 10.4:1 but a Tahoe is a little heavier than a RCSB
#25
Yeah it was around 9.2:1 give or take, so I thought that would be alright. Some info I've found on the LS9 head gaskets compressed is that they're around .040-.052. I plan to get the LS3 heads worked over some, so it will probably be closer to 9.3-9.5:1 in the long run.
Roger is a god amongst men when it comes to blown ls engines, so he's probably right
Abuckeye
08-19-2015 06:11 PM
05GMC4.8
08-07-2015 09:55 PM
