View Poll Results: What cam does my 4.8 need
220/220 .581/.581
13
59.09%
220/220 .564/.564
40.91%
Voters: 22. You may not vote on this poll
Help decide between these two cams
Old May 26, 2010 | 01:43 AM
white1's Avatar
Default Help decide between these two cams
This is for a daily driver 4.8. Right now Im going to use a Trailblazer torque converter, but plan to step up to a 3000-3200 Circle-D in the new future.
I was planning on using a set of Comp 918 springs I had, so I was set on the .581 lift, but got to doing some research and wondering if I may be just as good going with the lower lift and some LS6 springs.
Also help me decide on my LSA
Cam 1. 220/220 .581/.581 Comp XER lobes
Cam 2. 220/220 .564/.564 Comp XE lobes
I thought I wanted a 112 LSA + 4, but now Im thinking I may want a 110 +2 or +4
Help me decide.
Old May 26, 2010 | 06:43 AM
LS1TRUCKGUY's Avatar
gonna stick with the stock heads? if so i would go with the .564 lift. it would sound tough on a 110 lsa
Old May 26, 2010 | 11:45 AM
Foxxer's Avatar
220/220 .564/.564, nuff said.
Old May 26, 2010 | 11:48 AM
BlackGMC's Avatar
Resident Retard
220/220 .581/.581 110+4. The xer lobe are supposed to be easier to tune at idle due to the faster opening/closing rates. The stock heads will flow fine with that lift too... Just my .02
Old May 26, 2010 | 11:52 AM
BlackGMC's Avatar
Resident Retard
Also the 106 ICL I suggested above will make more TQ due to the increased DCR, which the 4.8 needs as much TQ as it can get. The increased overlap with the 220/220 110lsa with help in the upper rpms where the 4.8 really starts to come alive.
Old May 26, 2010 | 11:37 PM
budhayes3's Avatar
PT's Slowest Truck
Depends on the heads IMO, lower lift for stockers, higher lift for worked heads...I'd run PAC 1218's for either considering how high you're going to have to spin it in a 4.8. I like the 112+4 also because I'm a little more LS traditional lol, but a lot of guys have been running tighter LSA's lately with good results...^^^
Old May 27, 2010 | 01:13 AM
white1's Avatar
It's gonna be the factory bone stock heads.
Bud, it's a temporary engine. I'm either gonna reuse my old comp 918s or new LS6. As crazy as it sounds I'm trying to half *** do it on a budget
Old May 30, 2010 | 10:27 AM
03 BLACKOUTSSS's Avatar
Personally, id go with the .564" on a 112+4. Lift will suit your stock heads, the 112 lsa will give you a flatter curve than the 110, and the +4 will bring the power in sooner. I think that cam will be a monster in that motor. I will be swapping my cam in the future to something like that, just a bit bigger to suit my mods.
Old May 30, 2010 | 11:40 AM
bluecajun5.3's Avatar
11 Second Truck Club
just get a tr220 from thunder.
Old May 30, 2010 | 11:57 AM
MPFD's Avatar
He's got a point, (wish I knew what else he has) but its a killer cam in his truck...
